Prep Time
Cook Time
Total Time
15 minutes
1 hour
1 hour and 15 minutes
If you’ve ever tried sous vide lobster tails, you’ll surely know how incredibly tender, almost buttery, and luxurious texture they can be, which simply can’t be matched by steamed or grilled lobster tails. Don’t be intimidated by this fancy cooking method, it’s actually very straightforward and nearly hands-off. Just set the time and temperature, and you can easily replicate this recipe. Doesn’t it sound amazing? Let’s get started!
Ingredients:
  • 4 lobster tails
  • 4 tablespoons unsalted butter
  • 1 clove garlic, lightly crushed
  • 4 sprigs of fresh thyme
  • Lemon zest
  • Sea salt and white pepper to taste
Equipment:
Why Choose Sous Vide for Lobster Tail?
Frankly, most cooking methods punish lobster. High heat makes the muscle fibers contract hard and fast, squeezing out moisture. Miss the perfect window, and you’re chewing for a while.
Sous vide keeps the temperature exactly where you want it. You can hold the lobster at 130°F without ever overshooting, and the meat stays soft and moist. Apart from that, it is literally a hands-off work, and gives you plenty of wiggle room without sacrificing quality.
Sous Vide Lobster Tails on Plate
How to Prepare Lobster Tail for Sous Vide?
You’ll remove the meat from the shell before cooking. Some people leave the shell on, but that blocks the butter and herbs from reaching the flesh, and the shell could potentially pierce the bag.
Use kitchen shears to cut down the centre of the top shell, from the wide end to the tail fin. Stop before the fin. Gently pull the shell apart and lift the meat out. Pull the dark line that runs along the back of the meat off. Pat it dry with paper towel and sprinkle a little salt and white pepper. Place the tails in a single layer inside the bag. Add butter, garlic, herbs, and lemon zest. Seal tightly with your vacuum sealer or the water displacement method.
Preparing Lobster Tails for Sous Vide
Sous Vide Lobster Tail Time & Temp Chart
Lower temperatures give you a softer, almost custard-like texture. Higher temperatures give you the familiar flaky lobster you’d get from a good steaming. I personally prefer 135°F. It gives you enough structure for a sear, but the inside stays juicy.
Texture
Water Temp
Time
Sashimi-style
120°F (49°C)
45-60 minutes
Very tender, slightly translucent
130°F (54°C)
45-60 minutes
Traditional flaky, still moist
135°F (57°C)
45-60 minutes
Firmer, similar to boiled lobster
140°F (60°C)
30-45 minutes
INKBIRD ISV-300W
How to Sous Vide Lobster Tail?
Once your water bath is preheated and the bags are sealed, the cooking part is almost boring. That’s the point.
  1. Set your circulator to your chosen temperature.
  2. Lower the sealed bags into the water. Make sure the bags are fully submerged.
  3. Set a timer according to the chart above.
  4. Walk away. Do something else. The lobster won’t overcook.
  5. When the timer goes off, pull the bags out.
You can also try my Sous Vide Salmon Recipe or Sous Vide Shrimp Recipe. Then comes the finishing step. Do not skip this.
Cooking Lobster Tails Sous Vide
Drying and searing
Take the lobster tails out of the bag. Reserve the bag liquid for the butter sauce. Place the tails on a paper towel and pat them completely dry.
Heat a cast iron skillet over high heat. Add a thin layer of avocado oil or ghee. Sear each tail for 30-45 seconds per side. You’re looking for a golden-brown crust, not blackened. Alternatively, use a kitchen torch. Torches give you more control and less risk of overcooking the thin edges.
Serve immediately after searing.
Sous Vide Lobster Tails in Butter Sauce
How to Make the Butter Sauce?
The liquid left in the bag is already infused with lobster juices, butter, and aromatics. Don’t pour it down the sink.
Pour the bag liquid into a small saucepan. Warm it over low heat. Whisk in one or two extra tablespoons of cold unsalted butter, one piece at a time, until the sauce thickens slightly. Add a squeeze of fresh lemon juice and a pinch of salt.
Drizzle it over the seared tails or serve it on the side for dipping.
Making Sous Vide Lobster Tail Butter Sauce
What to Do With Sous Vide Lobster Tail?
These tails are good enough to eat on their own with the butter sauce. But if you want to turn them into a proper meal, here are a few ideas.
  • Lobster rolls - Chop the meat, toss with a little mayonnaise, celery, and chives. Pile into a buttered, toasted split‑top bun.
  • Lobster pasta - Toss the whole tails or chopped meat with fresh tagliatelle, the butter sauce, and a handful of parsley.
  • Lobster benedict - Replace the Canadian bacon with a piece of sous vide lobster on an English muffin. Top with poached eggs and hollandaise.
  • Lobster mac and cheese - Fold chunks into a creamy baked mac. The sous vide lobster stays tender even after a second heat.
You can also chill the cooked tails (before searing) and slice them thinly for a lobster salad. Cold sous vide lobster has a texture closer to crab meat.
Sous Vide Lobster Tail in Bun with Chips
Can I sous vide frozen lobster tail?
Yes. Place the frozen tails directly into the bag with butter and seasonings. Add 15-20 minutes to the cook time.
Do I need to remove the black vein?
Yes, you should. It’s the intestine. It won’t make you sick if you eat it, but it has a gritty, bitter taste that ruins the texture.
Is sous vide lobster safe to eat at 130°F?
Yes, as long as you hold it at 130°F for at least 45 minutes, which is long enough to pasteurize. If you have health concerns, stick with 140°F.
Can I sous vide lobster tail with the shell on?
You can, but I wouldn’t recommend it. The butter and herbs won’t soak into the meat, and the shell could pierce the bag.
