Prep Time |
Cook Time |
Total Time |
20 minutes |
3 hours |
3 hours and 20 minutes |
If you have never made an oven pot roast, you have to try this recipe. Just follow the steps, and you’ll get a perfectly cooked dish that is super tender, moist, and bursting with flavor. The beef practically falls apart when you look at it, and the carrots and potatoes soak up all that rich, beefy juice. I’m sure this will be the only oven pot roast recipe you’ll need from now on.
Ingredients:
- Beef chuck roast
- Salt and black pepper to taste
- 2 tablespoons olive oil
- 1 large yellow onion
- 4 cloves garlic
- 2 cups beef broth
- 1 cup dry red wine
- 2 tablespoons tomato paste
- 4 carrots
- 1.5 pounds baby potatoes or Yukon Golds
- 3 sprigs fresh thyme
- 2 sprigs fresh rosemary
- 2 bay leaves
- 1 tablespoon Worcestershire sauce
Equipment:
- Dutch oven
- Probe meat thermometer
What is the Best Cut for Oven Pot Roast?
You may have used brisket, round, rump roast, or shoulder to make oven pot roast, but if you want the result to be as silky-smooth as butter, chuck roast is the only right answer. This cut has a plenty of connective tissue and fat, which break down into gelatin when roasted, making the meat tender, moist, and melt-in-your-mouth.
RELATED: How to Cook a Thick Steak?
Oven Pot Roast Temperature & Timing Chart
Every oven runs a little differently, but here’s a temperature and timing chart for your convenience. However, for the best result, it’s best to use a wireless meat thermometer. When the internal temperature reaches 160-170°F, the meat is perfect for slicing. When the internal temperature reaches 200-205°F, the meat is perfect for shredding.
Weight of Roast |
Oven Temperature |
Covered Time |
2-2.5 lbs |
325°F (163°C) |
2-2.5 hours |
2.5-3.5 lbs |
325°F (163°C) |
2.5-3 hours |
3.5-4.5 lbs |
325°F (163°C) |
3-3.5 hours |
4.5-5 lbs |
325°F (163°C) |
3.5-4 hours |
How to Cook Beef Pot Roast in Oven?
Here’s how I do it. Follow these steps to make the perfect oven pot roast!
Step 1: Preheat and season
Set your oven to 325°F. Take the chuck roast out of the fridge 30 minutes ahead of time. Pat it completely dry with paper towels. Season all over with salt and pepper.
Step 2: Sear the meat
Heat a tablespoon of oil in a Dutch oven over medium-high heat. Place the roast in the pot. Leave it alone for 3 to 4 minutes per side until dark brown. Use tongs to flip. Remove the roast to a plate.
Step 3: Build the liquid base
Turn heat to medium. Add chopped onion and cook for 3 minutes, scraping up brown bits. Stir in smashed garlic and tomato paste for one minute. Pour in red wine, let it bubble for 2 minutes. Then add beef broth, Worcestershire sauce, thyme, rosemary, and bay leaves.
Step 4: Start roasting
Put the roast back in the pot. Insert your wireless meat probe into the roast. Set the alarm for 200°F. Put the lid on, and slide the pot into the oven. Roast according to the time chart above.
Step 5: Add vegetables
Take the pot out. Remove the lid. Scatter carrot chunks and potato pieces around the meat. Push them into the liquid. Put the lid back on. Return to the oven and cook until the thermometer hits 200°F to 205°F. The fork should twist easily in the meat.
Step 6: Rest, then serve
Take the pot out of the oven. Move the roast to a cutting board. Cover loosely with foil and rest for 15 minutes. Spoon off excess fat from the liquid. Slice against the grain or shred with two forks. Serve with vegetables and plenty of gravy.
More Beef Recipes You May Like:
What to Serve With Oven Pot Roast?
The pot roast with potatoes and carrots already covers a lot of the meal. But sometimes you want something extra.
- Crusty bread - For sopping up gravy. A baguette or sourdough works perfectly.
- Mashed potatoes - Yes, even if you already have potatoes in the pot. Some people like both.
- Egg noodles or buttered rice - The gravy loves a starch.
- Roasted green beans - A little brightness and crunch next to the tender meat.
- A simple green salad - With a sharp vinaigrette to cut through the richness.
- Horseradish cream - A spoonful on the side wakes everything up
Storage & Reheating Tips
Pot roast might be even better the next day. The flavors keep deepening overnight.
To store: Let the pot roast cool completely. Put the meat, vegetables, and gravy in an airtight container. It keeps in the refrigerator for up to 4 days.
To freeze: Portion into freezer-safe containers or heavy-duty zip bags. Squeeze out the air using a vacuum sealer. Freeze for up to 3 months. Thaw overnight in the fridge before reheating.
To reheat: The microwave works in a pinch, but it tends to dry out the meat. Instead, reheat gently on the stovetop or in a 300°F oven. Put the meat and gravy in a covered baking dish or small pot. Add a splash of beef broth or water to loosen things up. Heat until warmed through, about 15 to 20 minutes.
FAQ About Oven Pot Roast
Should pot roast be covered in the oven?
Yes, always. The lid traps steam and moisture. Without a cover, the liquid evaporates too quickly. If your lid is loose, seal the pot with a layer of aluminum foil before putting the lid on.
How to keep my oven pot roast moist and tender?
To keep your oven pot roast moist and tender, here are some tips:
- Pick chuck roast with rich marbling
- Cook low and slow at 325°F
- Use the wireless meat thermometer
- Add broth and cover with a lid
- Let the meat rest
What types of carrots are the best for this recipe?
Regular orange carrots cut into 2-inch chunks hold up well. Baby carrots get mushy faster. Farmer's market carrots taste great but add them during the last hour.
